Engine miss
Old Oct 5, 2010 | 09:36 AM
tampatony's Avatar
Default Engine miss
Hello all,
I have a 2001 V6 3800 camaro with a slight engine miss at idle. It is not noticeable while driving. If this miss is due to a burnt valve or head gasket issue, what would be the result if I continued driving the vehicle without making the repair. Thanks in advance for any information you provide.
Old Oct 5, 2010 | 10:33 AM
I am not sure about your diagnosis, but a burnt valve or a bad head gasket will just get worse with time. A bad gasket can lead to coolant into the combustion chamber, and overheating, and all the bad things that go with them. A burnt exaust valve will just get worse, and the leaking hot gases can cut through the valve seat and eventually damage the head.
Craig Ferguson
Apr 7, 2015 08:16 AM
Bassopottomous
Oct 5, 2011 06:36 PM
gadmhahn
70-81 V8 Tech
16
Aug 27, 2010 12:13 AM
sr1239
Jul 11, 2010 10:48 PM
94 Camaro 3.4
Jun 13, 2007 09:10 PM
