engine help needed
engine help needed
okay on my new motor i have got it all togethere down to the carb no valve pansi decided to go over my head bolts one last time well one of my head bolts is striped out any ideal how i can fix this with out taken back apart or what should i do
If you pulled the threads out of the block you will need to disassemble it down to the deck. You can helicoil it ar drill it to the next size if you drill it to the next biggest size you will need to drill the head also. I believe I would try the helicoil first, I always run a tap through all of the head bolt holes before assembly and use thread sealer. At least it wasnt a main stud........
