EMERGENCY OIL FILTER PROBLEM
Old Jun 3, 2006 | 12:48 AM
Vampirex's Avatar
Default EMERGENCY OIL FILTER PROBLEM
So I need to change my oil soon and i recently went to a store and bought a FRAM PH30 filter. The book in the store said it was the one to use on a 350 V8 and since that is what I have in my 2001 SS i figured it was the right one. Anyway i later went online to make sure and the FRAM website said that for a 01 SS that it was some other number that was not PH30 but PH3506 I was wondering if i got the wrong filter or that mabye it was just listed wrong
Old Jun 3, 2006 | 01:46 AM
94Z28SHAKER's Avatar
Default RE: EMERGENCY OIL FILTER PROBLEM
the one you bought will work, but the other one is probably bigger.
Old Jun 6, 2006 | 07:41 PM
mattvogt's Avatar
They make all different types for the same car. You are probably ok
Old Jun 9, 2006 | 09:18 PM
Your engine is not a regular 350, you have a LS type engine which is totally different from the old 350 small block. The filter will probably work OK as far as filtering, but the bypass valving may be different and not suited to your engine. I would spend another 5-10 dollars and put the right filter in.
Brayan99
Jul 2, 2011 08:56 AM
Rusk
Jul 26, 2010 06:30 PM
Puck90a
Sep 29, 2009 10:22 PM
Pro_built7
82-92 V8 Tech
Aug 7, 2007 09:33 PM
Pro_built7
May 21, 2007 02:41 PM
