dyno results
dyno results
is 225hp and 351 torque respectful.i didnt think so .the engine is coming out and a new cam,heads and intake are going back in.after the dyno run i felt a big disappointment and just disgusted.those numbers are way off from what i expected,the car pulls real hard and will throw you back in the seat.i find nothing respectful about it .this is a 78 camaro with a 454 ,400 turbo and 370 rearend
RE: dyno results
while doing 100mph on this dyno,its supossed to factor in the wind and everything else as if you were going down the freeway at 100mph.the dyno was call a mustang dynamometer,had two drums that supplied resistance all the way thru the pull
RE: dyno results
a stock 454 puts out 245 to the flywheel,while my motor has stock rods,crank ,block and heads.it has hyd.roller xr-282,roller rockers and lifters,9.5 compression speed pro pistons,781 castingbbc heads,they are suppossed to be one of the better stock heads,balanced,highrise-split plenum,750 holley-mechanical secondaries,flamethrower distributor
RE: dyno results
I presume the 225 number was measured at the rear wheels? That would put your flywheel h.p. in the neighborhood of 265 h.p., still not killer numbers consideringthe big block's potential.Figuringthe modest modifications it has now, it doesn't sound too far off base compared tothe stock rating.
RE: dyno results
ya it was measured at the rear wheels.i never knew how hard or how much it really took to get 300-400 h.p..there was full blown race cars there that was puttin out 400hp and when i say full blown i'm talking about slicks ,sheet metal bodies ,roll cages,no blowers.there was a trailblazer s/s that put out 467h.p. and over 500torque,he special ordered it with a vette motor,talk about a sleeper
RE: dyno results
No Sir he didn't order that SS trailblazer l i k e that they come from the factory with a 400 hp LS2 engine. If it has 467 at the wheels it is built pretty good especially if it is the AWD version.
RE: dyno results
Thats not too bad. With some good timing to the carb and timing you could probaly get a better pull. The numbers are a little low for a 454.
RE: dyno results
the last pull was the best and it produced the numbers i posted and that was from a dead stop.the tech doing the dyno said the spark became very erratic.the week before i was going to a car show and i thought i had plug fouling but then it cleared up.i think i have a distributor issue ,i have went thru 4 boxes of plugs since getting this engine running 3 years ago.i have played with the jetting and the timing.went smaller on the jets ,it would not run ,went bigger and it would load up and just about stall
RE: dyno results
well i found out why the timing was erratic.the fly weight studs on top of the distributor came out,not allowing the the weights to work.how would this affect the hp/tq rating
