correct routing heater hoses to heater valve
Old Jan 5, 2008 | 08:25 PM
dhighway's Avatar
Default correct routing heater hoses to heater valve
I have a 91rs with a 305 tbi, does anyone no the correct line routing of the heter hoses from the core to the vacuum controled heater valve? i cannot find a scematic anywhere, and cannot get heat from my heater? heater has been replaced as well as the water pump, and new t-stat. car operates at normal temp around 220 degrees, but still no heat? can anyone please help me. Thank you, dhighway.[sm=feedback.gif]
Old Jan 5, 2008 | 09:28 PM
dhighway's Avatar
Default RE: correct routing heater hoses to heater valve
Come on guys i know there are members with this valve on there car! its called the heater vacuum controlled bypass valve, i think for switching between heat and ar conditioning, it has 3 heater hose connections the 2 tha come off the heater core and 1 for the top of the intake manifold, mine was bypassed with a tee assembly, but kept throwing codes, and made the compressor cycle alot, and yes it has been leaked down and recharged, i just need to know the correct connections to the valve and so on, send a pic of your engine bay, but only if your car blows heat and air correctly, cause mine does not! and im running out of ideas? thanks alot for any and all help, you can send. later fellow camaro lovers.[sm=ttiwwp.gif]
Old Jan 5, 2008 | 09:53 PM
dhighway's Avatar
ok if i dont get help soon? look for a 91rs with all the bells and whistles and a killer stereo w/dvd, to go up on the auction block! god i hate to say this, but i might have to buy a FORD? man my tongue almost snapped off.[sm=drooldude.gif]
Old Jan 6, 2008 | 09:41 AM
Twitch E. Leprechaun's Avatar
I have a 92 Rs with the heater valve, I just had to replace it. It is sitting at my wharehouse right now though. let me get a pic of the valve and hoses and I will have it up later tonight.
Old Jan 12, 2008 | 07:28 PM
dhighway's Avatar
ok Twitch, still awaiting pics? and the car is awaiting pics, course with the weather were having! she's happy sittin under cover, will wait for info, hopefully before summer comes? lol Thanks for all and any help sent this way.[sm=feedback.gif]
JohnnyCars
Dec 20, 2012 06:59 PM
MARVIN SEIP
Jan 27, 2009 04:49 PM
RobsWreck98
Nov 7, 2008 04:06 PM
tobyte1
Aug 20, 2008 08:02 PM
camarohelp
Dec 29, 2006 08:10 PM
