clutch...i know this is an engine section but...
Old Nov 30, 2008 | 11:48 PM
sprtsfrk's Avatar
Default clutch...i know this is an engine section but...
Alright guys so i finally got my 383 running pretty good. but now im having clutch issues. i bought the mcleod clutch kit that fits the 95 camaro 5.7L, it is the twin disc with a steel flywheel from mcleod, mcleod pressure plate for it, and i have the stock pivot fork. i also bought the adjustable master cylinder to go along with it. i installed it into my hydraulics and bled the system quite a few times. the adjustable master is adjusted so its 1" lower than the brake pedal. Now heres the problem. when i push the clutch pedal all the way in it feels as though its hitting something and having pedal kickback, similar to an abs module. and it syncs with the engine rpm. it wont go into gear, and as long as i dont push the clutch all the way in obviously it can start. now i know youre going to say, pull the trans and see what parts are hitting, itl be shown by clean scrape marks yata yata. i dont have a lift here at home, and nor do i have a garage and we just got snow here in chicago. how gay... anyways, i was hoping someone knows a quick fix or what is wrong with it if theyve had this problem. the shop who did the engine work w the balancing balanced my motor with it on there so im not sure if its set up 100% correctly. if all else fails im towing it to work and puttin it on the lift and rippin it apart to find out. thanks in advance guys!
AMBAPTISTA
Oct 28, 2010 01:53 PM
1971BB427
Northwest
Feb 22, 2010 07:29 PM
Pro_built7
Apr 10, 2007 02:07 AM
