Checking Push Rod Length
Old Jan 29, 2010 | 09:00 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Checking Push Rod Length
I bought an adjustable push rod length checker for my build. However, the diameter is too large to fit in the slot in the guide plate.
What's my way around this?
Old Jan 29, 2010 | 09:34 AM
take the guide place off, do your thing, put it back.
Old Jan 29, 2010 | 09:40 AM
Yep, that's what I was gonna say too. You'll only have to remove one of them anyway.
Old Jan 29, 2010 | 09:44 AM
August 2009 ROTM
This is what I had planned, but I didn't know if not having the guide plate in would affect the valvetrain geometry and give me an inaccurate measurement. I'm sure I will need a washer of the same thickness as the guide plate then too, correct?
Old Jan 29, 2010 | 10:07 AM
nope dont need washer, the plate missing will not effect valve or rocker movement. guide plate is for when the motor is running so the pushrods dont bouce out of place on high revs. i would retouque the bolts but i dont know that is required.
Old Jan 29, 2010 | 10:20 AM
Taking out the guide plate isn't going to be changing your rocker arm to valve stem geometry. In essence, you're just changing the height of the stud.
Old Feb 2, 2010 | 09:23 PM
kyphur's Avatar
The nut will only let it go down so far since the tip is resting on the top of the valve stem and the rear is on the pushrod. The arm stud is just to make sure it's held at correct lash.
What type of cam are you running?
z28pete
Mar 13, 2023 03:57 AM
carguylt1
Mar 4, 2012 04:46 PM
craby
Jul 22, 2010 12:51 PM
cbr600rx7
Sep 6, 2009 07:21 PM
joeyninetoes
Nov 29, 2007 08:01 PM
