cam Question
Old Jul 6, 2007 | 10:33 PM
mookdawg's Avatar
Default cam Question
what kind of cam would i need to get that slow lopingsound for my 350
Old Jul 7, 2007 | 01:28 AM
VQMaxFan's Avatar
Default RE: cam Question
lunati 00017LK is what im running, its lopey as hell, you almost need a stall with it
Old Jul 7, 2007 | 09:00 AM
GRIFF's Avatar
I have the older style single duration 270 magnum in the car now it is adverized as the largest duration you can run with a stock converter so far I like it. Ill try to record the sound of it later today it has open headers though.
Old Jul 7, 2007 | 09:16 AM
machineman's Avatar
If that is all you are looking for then use a cam with a narrow lobe seperation like the Comp Magnum cams since they are all at 110. Also, put as much duration in it that you can and it will be as lopey as you could want it. Will it make great HP and torque? That is a different question.
Old Jul 7, 2007 | 06:53 PM
mookdawg's Avatar
well would i be able to drive it daily
Old Jul 7, 2007 | 10:10 PM
Depends on how much of a masochist you are. If you are into whips & chains, you will be right at home with that kind of a cam.
Old Jul 8, 2007 | 03:34 PM
Auji350's Avatar
I am in the Same boat.Also looking for that sloppy noise!I've Just got my car and im still not Fimilar with the componentsas i had a Ford before. I've been searching on Summitracing.com and i see alot of different Lunati Cams. Which one do i Go with? If one of you guys can help me out im all ears! thanks!
Why is there so many different Cam Stlyes?
Old Jul 8, 2007 | 10:00 PM
GRIFF's Avatar
These are two clips with a 350 with a 270 cam very mild vortec headed engine the idle one didnt come out very good I must have been to close it really isnt that bad. The second one some guy in a bikepulled in but you can still hear the car ok. The carhasrun in the 8.20s (1/8th) but today was really hot andhumid I think the car is capable of seeing the high high 7s with better air and better tune(carb)
<center>
<a href="http://s99.photobucket.com/albums/l3...t=100_0898.flv" target="_blank">
<img src="http://i99.photobucket.com/albums/l310/CAMORORACING/th_100_0898.jpg"></a>
<a href="http://s99.photobucket.com/albums/l3...t=100_0892.flv" target="_blank">
<img src="http://i99.photobucket.com/albums/l310/CAMORORACING/th_100_0892.jpg"></a>
</center>
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
