Cam ID help?
Old Sep 14, 2006 | 01:47 AM
Y2K's Avatar
Y2K
Default Cam ID help?
I've had this small block solid lifter cam laying around quite a while and would sure like to get some specs on it.
Got a from a guy quite a few years back that said it was a Melling solid lifter cam that was new and he never used it but he had lost the specs on it.
Any idea how to ID this thing?
It's got letters and numbers in a few different places on it.
On the back ( distributer) end it has C800P and then K17 5 I think,hard to read the latter.
On the shaft behind the fuel pump lobe it has RSCD and the # 55 under the letters then in the same place on the shaft on the other side is the letters CWC.
Then there's C1 on the shaft behind the 3rd bearing journal.
None of this means beans to me but I thought maybe one of you motor heads might know something about it.
Anyone here able to shed some light on this mystery cam?
Old Sep 17, 2006 | 12:32 AM
Y2K's Avatar
Y2K
Default RE: Cam ID help?
bump............ [sm=bounceybounce.gif][sm=feedback.gif][sm=groupwave.gif][sm=happybounce.gif][sm=massbounce.gif]
Old Sep 17, 2006 | 04:19 AM
Slayer's Avatar
The only thing i can tell you is that some of there cams are suppose to be close matchups to the edelbrock performer cams
Old Sep 17, 2006 | 02:43 PM
Y2K's Avatar
Y2K
ORIGINAL: Slayer
Thanks for the feedback,this is a solid lifter cam so would need valve lash settings at a minium.
