cam help please
Old Nov 8, 2011 | 06:46 PM
jackss00's Avatar
Default cam help please
Hi i have a 2000 camaro ss with 5600 miles on it.Its an automatic with headers, intake lid /filter,and catback.I was thinking of getting a cam and all tht goes with it but i do not know where to start.
Is there any other mods i should do before a cam.I have done a little research on ms3 cams but i dont need nothing too extreme and expensive bc its my dd,id just like it to lope,but i want to do it right.Ive thought of gm hot cam but have read that its not worth the money and should go bigger.Any input is appreciated thanks.
Old Nov 8, 2011 | 07:57 PM
greenmachine96's Avatar
Maybe a a new torque converter with a higher stall. This one would probably be pretty streetable and sound pretty good too..........
http://www.compcams.com/Company/CC/c...csid=1402&sb=0 .... Pretty impressive rpm range on this cam too. More aggressive than the hot cam and should produce a good bit of power.
Last edited by greenmachine96; Nov 8, 2011 at 08:03 PM. Reason: Posted wrong link lol
Old Nov 8, 2011 | 08:08 PM
Check it out found you a video of that cam... 99 Trans Am LSR cam idle video (untuned) - YouTube
Old Nov 10, 2011 | 08:39 PM
jackss00's Avatar
where is a good place to get the whole kit
Old Nov 11, 2011 | 07:04 AM
right from comp cams..... I tried to find it on their site but I couldnt. I know if you call them they can get it for you though. Just tell them the grind # and part #.
Old Nov 13, 2011 | 07:41 PM
jackss00's Avatar
how much is all this going to run me?i was also thinking of getting an ls6 intake manifold
Old Nov 17, 2011 | 10:13 AM
If you're trying to get a complete kit with a double roller timing chain, valve springs and etc., about 8 or 900 possibly up to 1k. Im not positive though so your best bet is to contact the comp cams tech support and get prices from them. Tell them you want the complete kit not the cam and lifters only kit. The Ls-6 intake would probably help to feed the motor with this cam so it might be a good idea to do both at the same time. Might also want a larger throttle body too.
