Cam engine Idle
Cam engine Idle
I want to know what the best idle is for an A I cam 568' 569 lift would be. Should i just keep it a 1000rpm. Are what should i lower it to to get that distinctive rumble but without making the car struggle to stay started
you'll need it all re-tuned to make sure it runs right, you can do it youself with a hypertek but if you have already had it tuned because your running a charger you dont want to wreck that. if the car itself runs right up the rev range under WOT i would leave it or get it done by a proper tuner
