another head /cam question
Found a set of heads that have had work done to them for $300 the work was done by a local and good machine shop. will be taking my block to the same shop.
these would be for a 350 i am building.
Now my question it was also noted that he would be using a Hydraulic roller cam.
should i be able to use a Hydraulic flat tappet cam without having to change anything on the heads.
Lastly is this a good deal?
casting 8827186
Here is some stuff on the invoice
Valve job &magnaflux
install 16 guides
8x stainless 2.02 in manley 10750
metal viton seals
3/8 rocker stud
$355 worth of work plus the cost of the heads.
install 16 guides
metal viton seals
3/8 rocker stud
