4th gen f body engine removal
Found this and thought i'd share. This is a how to on removing the engine/trans from the bottom on an LS1 car but should be pretty similar to the lt-1 cars too.
LS1 Engine Removal in an F-Body - YouTube
Having a lift would make all of the difference in the world with this job but i had this link in my favorites. IDK if i found it on the forums or i stumble on it. but here is a write up on how to do this with out a lift. Seems like it could be done easily in you home garage. Engine Removal
well having a lift support would be able to be much easy for you to do the job. actually in jcwhitney they have a lot of strong arm replacement lift suppports and accessories that you can find..
Well dropping it from the bottom the motor and trans will still be bolted together with the motor still on the k member so you would not have to pull the trans. I have done this twice without a lift. Just as easy just takes a wee bit longer. If you got a good hoist. Now if I was removing my 350 out of my third gen from the top, it it a lot simpler to keep the trans bolted to the back of the block untill its out.
