383 stroker question...
Im thinking of buying a 1995 Z28. The guy told me that it has a 383 stroker kit. What is a stroker kit? Is it a 383 engine or a LT1 with certain kit parts on it? Also is this more HP than an original LT1? Can it be used for a daily driver? It also has a 2500 stall converter installed...
Ronnie
Ronnie
A 383 stroker is a 'kit', so to speak, that you add to your original engine (whether it's an old school sbc 350, lt1, or ls1). The additional cubes come from the swapping of the original crank with a 400 crank, and a .030 over-bore. If built correctly, yes, it will have substantially larger amounts of horsepower over the stock lt1. If it's built correctly, and that 2500 stall reflects a relatively mild cam, then yes, it'll be very easy as a daily driver.
383, 95, build, camero, chevy, exhaust, horsepower, l82, lt1, nos, sbc, streetstrip, stroker, system, wwwblueprintmotorscom
