383 stoker flywheel
Old Aug 29, 2011 | 08:13 AM
old timer's Avatar
Default 383 stoker flywheel
Need some help guys.
I inherited (long story) a zero mile 383 externally balanced stroker. I have little info on the parts used, it is an older block two piece rear main seal that has a forged stroker crank with the one piece seal adapter. The engine has run on a test stand with an auto flywheel. I would like to put this engine in a standard shift gen 2. What flywheel will I need? Thanks Old Timer
Old Aug 29, 2011 | 08:44 AM
One that's made to be used on an externally balanced small block....the 400. Also check to make sure the crank is drilled to accept a pilot bushing.
Old Aug 29, 2011 | 10:50 AM
old timer's Avatar
That's what I thought but wasn't positive. Benn a long time since I played with this stuf. Thanks
Old Aug 29, 2011 | 10:51 AM
old timer's Avatar
Can't type for crap either!
Old Oct 18, 2011 | 03:03 PM
n97200's Avatar
Default Flywheel
Ive got a 700173 centerforce steel flywheel that i am told fits the 383/400 with 2 piece rear main seal. Its brand dang new, still in the box with all the centerforce paperwork and whatnot. If interested let me know, i will let it go cheap.
Thanks!
n97200@yahoo.com
bigjaycustoms69
Aug 6, 2013 08:04 AM
dogdog130
Aug 30, 2011 10:44 AM
dogdog130
Aug 24, 2011 06:31 PM
christian herring
VS
36
Sep 21, 2008 07:49 PM
red star
Sep 15, 2007 09:42 PM
