350
Old Dec 6, 2006 | 10:58 PM
Andross's Avatar
Default 350
Would a 350 from a 76 pontiac fit My 79 Camaro?
Old Dec 6, 2006 | 11:09 PM
SickSickSick's Avatar
Default RE: 350
Yes. Sick
Old Dec 6, 2006 | 11:15 PM
Andross's Avatar
Default RE: 350
Sweet! I'm gonna go get me a free 350 this weekend!
It will need rebuilding but its better than nothing!
Old Dec 7, 2006 | 12:39 AM
GRIFF's Avatar
Default RE: 350
Is it a pontiac or chevy 350 they used both in pontiacs. I would caution you a bit if its a pontiac they are a bit more costly unless you are doing a stock rebuild and I think the transmission/bellhousings are a different pattern than your chevy.
Old Dec 7, 2006 | 12:45 AM
Andross's Avatar
Default RE: 350
We shall see. It's all good. It's free after all
Old Dec 7, 2006 | 01:02 AM
GRIFF's Avatar
Default RE: 350
Free is good. I think you may need to play around with moter mount locations I think they a different location but you can make it work. The 350 is kind of the odd one I ran 400s and a 455 before and my buddy just got a ventera with the 350 its actually a pretty nice car and runs good. The 350 pontiac has a bore of 3.85 and a stroke of 3.75, simiilar in bore and stroke to a 305 with a 400 crank, I like the pontiacs but they are getting scarce 455s are bringing good $$$ today.
Old Dec 7, 2006 | 11:27 AM
uncle bill's Avatar
Default RE: 350
Griff is 100 % right. It is completely different including the transmission bolt pattern. Buick-Olds-Pontiac had their own bolt pattern for some reason. Much, much more expensive to rebuild also. Best bet, get another 350 Chevy and rebuild that, much less expensive in the long term. Remember, Free isn't always the best deal.
Old Dec 7, 2006 | 12:39 PM
Andross's Avatar
Default RE: 350
Well even if I cant use it, I could probably get atleast $150 outta it
Old Dec 7, 2006 | 02:43 PM
shnormo's Avatar
Default RE: 350
Even if it is a pontiac bell housing pattern, they do have adapters. I DO NOT! recomend them
