327 build advice
hey guyz, im looking to build a 327 maybe late this summer, or next winter..
heres what i want out of it..
325-375hp
300-350ft-tq
good mid range torque and high rpm hp..
im thinking used vortec heads, aluminum intake, 700cfm carb, a mildish cam that works from 3,000- maybe 7,000rpm, and i want to keep the stock bore and stroke if i can find a block in good enough condition so i can keep the stock internals (cleaned and balanced)..
and will a stock LS1 rear end with 3.42 grears hold up without breaking?
any other tips or anything you recomend?
325-375hp
300-350ft-tq
you could get the power and tq you want with all stock parts. i have a 327 in my 68 camaro thats the original #'s matching motor that is stil the orginal bore and stroke. i used date coded 68 202 camel hump heads with a gm 350 hp cam and a 1968 chevy parts over the counter aluminum high rise intake(exact same a 302/z28 intake just has a bowtie on the back runner) it's topped with an edelbrock 600 cfm carb. i dont know what rear end gears im running because i have never pulled my stock 12 bolt out yet. the ls1 rear will hold up but i think it might be too wide depending on what car you are putting it under.
sohcnick
03-25-2013 04:03 PM
1981camaroz28
10-23-2007 05:44 PM
