305 Rebuild - Need Advice
Old May 10, 2009 | 07:37 AM
Quinny's Avatar
Default 305 Rebuild - Need Advice
I am looking to improve the pathetic 165hp 305 in my 86 Z28. I have pretty much got the combination sorted out, but I need a couple of technical specs that I can't seem to find.
I need to know the head chamber volume and the volume between the piston top and cylinder deck (at top-dead-centre) to work out compression ratios.
I am looking at using the following:
Flat top pistons - not sure on brand yet
Stock rods
Edelbrock Performer RPM Air Gap
Holley 650DP Carby
New cam (222deg @ 0.050", .470 lift, 110LSA)
Ported heads with 1.94" valves
Flowtech headers, twin 2.5" exhaust
LSD with 3.73 diff gears
Looking for a nice reliable 300hp. This is a cruiser not a race car so I am not concerned about huge power, hence I am not bothered with going to the trouble and expense of a 350 swap.
Busa200
May 13, 2012 07:22 PM
Destoryer
Sep 19, 2010 01:58 PM
boatman2089
Jun 1, 2010 10:14 PM
brucehusker
Jan 17, 2009 08:14 AM
