Yellow headlights?
I just learned something new.. My headlights had turned yellow, tarnished like... a friend of mine recommended I use toothpaste and a damp towel.. I actually laughed at first but you know what, it worked. And I found it worked better with a green scuff pad and toothpaste.. anyhow, if your headlights are tarnished, give it a try, it worked for me.
RE: Yellow headlights?
you mean ur headlights lens were foggy because my left one is foggy looking
Yeah... mine just happened to be a yellowish color.. but yeah, they were foggy. If its on the inside I really dont know what to do about it,, but if its on the outside toothpaste will clean it... Takes some elbow grease, but it works... DO NOT use rubbing compound... it will scratch your lenses.
2000 GRIT WET SAND PAPER AND SOME WATER
SAND IT TILL IT IS SMOOTH AND CLEAR AGAIN WOOL PAD AND SOME 3M RUBBING COMPOUND VARIABLE SPEED BUFFER AND GUESS WHAT THEY ARE NEW AGAIN "BE SURE TO TAPE OFF ANY SHARP EDGES SUCH AS FENDERS, FRONT BUMPERS AND RAISE THE HOOD WHEN DOING THIS "COVER THE ENGINE SO COMPOUND DOES GET ON THE ENGINE". WASH CAR WHEN DONE TO CLEAN OFF ANY RESIDUAL COMPOUND. |
AutoSol and a buff wheel on drill!
your car is the sex u know that
i love the red lettering |
Me too, maybe he'll tell us where he got that. Is it paint or 'stick-on'? I tried to get a pinstriper to do mine (front & rear) but he wasn't interested!
hmm interesting. any certain brand you recomend? lol. oh and heres for you ppl wanting the letters. http://www.hawksthirdgenparts.com/in...amp;ProdID=205i had a post on them not to long ago.
Thanks a bunch for the info on the letters! You guys are great!
toothpaste and a toothbrush works alittle, you may need sand paper or a scruff pad like chrls_vns.
