Detailing Discuss detailing your ride within.
Caliper Paint
Old 10-16-2006, 02:52 PM
02blackonblack's Avatar
Default Caliper Paint
So yeah, I'm thinking I'm gonna paint my brake calipers red today. My brother did it on his modded probe gt and it looks pretty good, personally I think he should have went with the inferior ford blue, but what do you guys think? Red should be okay? Any suggestions on the easier ways of doing it?
Old 10-16-2006, 05:54 PM
shnormo's Avatar
Default RE: Caliper Paint
I personally like to take off the caliper and the caliper mounting brackets, spread the calipers, and put news paper under all the brake components. Reinstall everything and then paint them. Prepping them, just degrease them, I use brake cleaner and then prime it with self etching primper and then paint it. Sand it with 1000 grit sand paper and then clear em. Or you could be lazy and just degrease them and then tape off what ever you don't want painted and shoot the paint and clear.
Old 10-21-2006, 09:17 PM
Sweet, thanks.
Old 10-25-2006, 01:00 AM
shnormo's Avatar
Old 10-30-2006, 12:09 AM
gray89vert's Avatar
looks really nice on that cobra! I used the spray paint kind from duplicolor on my drums and they turned out pretty nice.
Old 11-09-2006, 11:25 PM
94CamaroSFI's Avatar
How long does the duplicolor paint take to dry (the brush-on style) before i can start driving it?
Old 11-09-2006, 11:59 PM
shnormo's Avatar
Well for duplicolor, I just sprayed the primer on let it set for 10 minutes and then while it was still a little tacky I sprayed the color. You can drive it as soon as the paint is dry to the toutch. It should be less than an hour.
Just don't glop it on and as long as it's light coats it'll be fine in an hour.
Old 11-10-2006, 10:30 PM
I painted my rear drum gloss black today using Dupli-color's brush on paint. i took my time sanding it down so it took almost 5 hours to complete, with a few breaks in between (my buddy came down and smoked with me anyways It is really a simple process just make sure you sand all the rust off that you possibly can. I might accent them with red eventually. Anyways like it's been mentioned before this isnt a quick process I got one drum painted in 5 hours.. The paint drys suprisingly quick. So (weather permitted) I'm going to move on to the next one. pics coming later tonight i have to reduce their size.
Old 11-11-2006, 01:28 AM
shnormo's Avatar
Sounds like a plan. A couple days after the paint has dried, if you want to accentuate the letterings in the drum, spray the red paint and let it fill in the lettering and then take a rag or cheese cloth and dip it with paint thinner and take the paint off the raised areas.
Old 11-11-2006, 04:42 PM
Yeah so heres the process. Must I stress How important it is to take your time sanding. I plan on accenting the center "lip(image 3)" of the drums red and each on of the raised "ribs (image 2)"
Heres Some pics
[IMG]local://upfiles/4475/E0E9F034B98146D288E23D3C2D698324.jpg[/IMG]
[IMG]local://upfiles/4475/89DC7FAE48284C48937BF615419546A7.jpg[/IMG]
[IMG]local://upfiles/4475/E8CC2C25860D4B8594565B620D3E30CE.jpg[/IMG]
[IMG]local://upfiles/4475/9D8B40600E07464696547AEB0C121B9A.jpg[/IMG]
Quick Reply: Caliper Paint
