Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Fuel Pump Relay.
Old May 7, 2007 | 03:31 AM
ChevyBuff's Avatar
Default Fuel Pump Relay.
89 RS.
Does the fuel pump relay have and control over the fuel guage ? The kid i got the car from had a bad relay and rather then replace the relay he hooked up a flip switch to turn the pump on and always left it on. so thats #1on my list to fix and the guage always reads just above full.after I fix my ignition cause someone broke into my car lastnight. And yes my car was locked up. but both doors were unlocked when i when out thismorning. But they didn't steal anything else.
Old May 11, 2007 | 12:36 AM
ChevyBuff's Avatar
Default RE: Fuel Pump Relay.
I take it nobody here knows the answer to this? Hmm
Old Mar 30, 2008 | 09:23 PM
82pacecar's Avatar
yes the answer is pretty late but the answer is no it doesnt have anything to do with you fuel gauge. either the wiring in the tank or the sender in the tank might be bad, or possible the float is stuck.
i just had the same problem and it turned out to be the wiring and the floater.
Old Apr 3, 2008 | 06:45 PM
miniman#1's Avatar
well i have a 1991 dodge dakota the fuel pump makes a relly loud noise could it be the pump is going bad answer asap
Old Apr 3, 2008 | 07:37 PM
ORIGINAL: miniman#1
Most likely, yes. Does it still make noise with a full tank?
chevyguy842010
Aug 19, 2011 01:55 PM
Chaotic94
Oct 11, 2010 02:54 PM
DevilGirl witha Halo
Apr 9, 2008 06:46 PM
buckfever
Dec 27, 2007 03:15 PM
tboneshep
Sep 22, 2005 09:41 PM
