fuel pump problem
fuel pump problem
i have a 78 camaro with a 454/400 turbo.its mildly beefed up.i bought a fuel pumpfor it .the fuel pump i bought was for a 396hipo.my problem is this.when i'm running the car in the shop the level of fuel in thefuel filter is about half full.when i rev it up or take it around the block and take it back in the shop the fuel level is just barely noticeable in the bottom of the filter housing.should i buy a aftermarket fuel pump like a holly or something.
RE: fuel pump problem
mechanical.the fuel filter has never been full since the day i fired this engine up,maybe 500 miles and that is in about a 18 month period.the float levels seem to be fine at idle.my fuel gage is a autozone cheapo so it sets there and bounces all over the place,it shows about 6-10 psi,avg 8..every now and then(not everytime)it pops and sputters on the top end and i'm just wondering if it is running out of fuel.if i was to get a holley pump,which one should i get.they offer different psi pumps.
they don't always fill all the way up,some air gets trapped inside,(breakan old one open some time and take a look at how they are put together)
Are you having any drivability or full throttle problems...you might consider installing a pusher pump back at the tank,
When we first put the 454 in the c-10, we used only the mech pump. it seemed like it ran fine, I decided to install an elecetirc pump as well, I was suprised at the difference it made..
on my c-10, we run a big mechanical with a holly 110 fuel pump back by the tank. we have the 3/8 inline filter right at the carb that uses the 1/4 return line. we runthe return line back to the tank. we also removed the fuel sock in the tank and run a big filter between the tank and the electric pump...
on my camaro, I run a larger electic fuel pump with a big spin on filter before the pump, ( no tank sock) I use 1/2 inch steel line to the front. I run 2inline 3/8 filters in parrallel both with return lines, to the tank.
greg
greg
