Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
code 36?
Old Dec 12, 2007 | 09:09 PM
1994z28's Avatar
Default code 36?
i pulled the code with my new scantool and it says, Code 36 Baro sensor signal low. Ok everywhere else i look a code 36 is a Distributor ignition system code. any ideas?
Old Dec 12, 2007 | 09:59 PM
Default RE: code 36?
What year and engine, TBI, TPI, MPFI, Carb, etc..??
Old Dec 13, 2007 | 07:20 AM
1994z28's Avatar
94 camaro z28, Lt1
Old Dec 13, 2007 | 11:05 AM
This is from the Factory Service Manual by GM. DTC 36 Distributor Ignition system (Faulty High Resolution Pulse or Extra Low Low Resolution Pulse Detected)
Old Dec 19, 2007 | 01:16 PM
1994z28's Avatar
found my problem. The distributor shaft bearing is shot(msd pro billit, less than a year old. i did not install)and the rotor is wobbling all over the place. So i need a new opti.
Old Dec 19, 2007 | 07:17 PM
You may just want to stick with a GM unit. IMO, MSD hasn't got the quality control part figured out yet. Again, that is just my opinion.
kalim03
82-92 V6 Tech
Feb 7, 2010 11:56 PM
tycomps
Feb 16, 2008 09:56 PM
crusherdrivinfool
82-92 V6 Tech
Dec 16, 2007 11:12 AM
350rs
May 16, 2007 09:02 PM
dblock1989
Mar 6, 2007 08:54 AM
