code 36?
i pulled the code with my new scantool and it says, Code 36 Baro sensor signal low. Ok everywhere else i look a code 36 is a Distributor ignition system code. any ideas?
RE: code 36?
What year and engine, TBI, TPI, MPFI, Carb, etc..??
RE: code 36?
94 camaro z28, Lt1
RE: code 36?
This is from the Factory Service Manual by GM. DTC 36 Distributor Ignition system (Faulty High Resolution Pulse or Extra Low Low Resolution Pulse Detected)
RE: code 36?
found my problem. The distributor shaft bearing is shot(msd pro billit, less than a year old. i did not install)and the rotor is wobbling all over the place. So i need a new opti.
RE: code 36?
You may just want to stick with a GM unit. IMO, MSD hasn't got the quality control part figured out yet. Again, that is just my opinion.
