Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
check engine light....help
Old Oct 11, 2008 | 11:19 AM
My01Z28's Avatar
Default check engine light....help
check engine light is on and i need it off to sell to a dealer. My car is catless so I'm sure that's the code. Would a cheap tuner be able to get rid of it. Found this one on amazon let me know if this will let me eliminate the code. Thanks
http://www.amazon.com/Actron-CP9175-...842&sr=8-3
Old Oct 11, 2008 | 01:50 PM
02StanGT's Avatar
Default RE: check engine light....help
Even if you clear it with that, it will come back in after driving a littleif the 'problem' is still there...
Old Oct 11, 2008 | 03:47 PM
It might work for you if you can clear the code right before you pull into the dealer. And then push the car onto their lot when they're not looking!
Or, you could take it to Auto Zone for a free scan to be sure of what the issue is.
Did your light go on right after the car became "catless" (definitely related)? Or was it a while after?
EagleRex
May 29, 2010 04:48 PM
ghanahost
Feb 21, 2010 12:49 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
gozzy341
May 20, 2007 11:00 AM
teamlilE1
Mar 12, 2006 02:22 AM
