Carb help
I have a v6 2.8l 84' camaro and i am attemting to rebuild the carb which is a 2se rochester 2bbl and for the life of me cannot fine a video on how to rebuild one.
i would consult my instructions that came with the carb kit but i am dyslexic with diagrams and cannot understand them at all. if anyone could help me out it would be greatly appreciated thank you. |
figured it out now im having the problem itll start but will not stay running it drops down to 500rpm n stalls out what do i do?
First make sure the idle mixture screw is set right, start with 1 1/2 turns out from bottomed out and tune it from there.
Then adjust the throttle stop screw on the linkage arm to get the curb idle to where you want it. |
thank you for the help did that all and then played with the vacuums a little and found a vacuum was drawing too much air as well
hey what about Youtube. i remember seeing a similar video there. try searching for it.
i once saw a video about this on youtube or dailymotion just go there and search
Don't forget to let us know how things work out.
