Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
94 cant pull codes from the obd 1 connector
Old Feb 7, 2010 | 04:03 PM
Thunder66's Avatar
Default 94 cant pull codes from the obd 1 connector
Hello all, I have a 94 camaro 3.4. Im trying to pull the codes from the computer but i cant. Ive heard that this may be a hybrid system. I do have the 12 pin obd 1 connector but points a and b will not do anythang. I seen the diagram sticky for the 95 to adaped the 16 pin car to the obd 1 tester. but nothing on this car. i was wondering if anybody had an idea on what to do to pull the codes, is this one of the hybrid cars as well? I have heard other peaple with the same problem with this type of plug and year but never heard how to pull codes!
Old Feb 7, 2010 | 10:20 PM
You need a OBDI scanner. Those $30 code readers won't work on your car. Can't flash codes on his model, although the FSM says you can.
Old Feb 7, 2010 | 11:36 PM
Thunder66's Avatar
Ok, Thanks for the help
OneHotMamma
Jan 18, 2015 08:24 PM
78 on my plate
Aug 22, 2012 11:10 AM
lvchev
Jul 4, 2010 11:46 PM
JoeKramer
82-92 V6 Tech
Apr 18, 2008 02:32 AM
sewerrat
Mar 23, 2007 04:29 AM
