Wiring Questions
If someone could look at their 68 or 69 Camaro to verify a couple issues I'm trying to solve, I would be most appreciative.
1. Is the Black/White wire for the amp gauge connected to the splice that's near the horn relay or is it attached directly to the same terminals as the 10 gauge red wire and fusable link at the horn relay?
2. On cars that have the glove box light, I've only seen a separate orange wire that plugs into the fuse box that powers the light. The assembly manual shows it it to be integrated into the harness. Which one do you have?
Thanks!
Larry
Thanks!
Larry
