wire running
Old Aug 24, 2006 | 01:26 AM
redstick1992rs's Avatar
Default wire running
hi, im a noob at camaros here. i just got new pioneer 6x9, 4x6 and cd player with a bazooka sub and power amp i want to know where is the easiest place to run audio cable and power for both in the car?? i have the bazooka in the very back of the trunk and the power amp i would prefer under the seat or on the left side on top of the gas tank (not screwed in but velcroed)
Old Jan 1, 2007 | 07:09 AM
91 RS's Avatar
Default RE: wire running
hey man i don't know what modle you got . but i got a 1991 rs and i put my amp in my trunk on top ofthe. T top mat with velcroe . but i drilled a hole were my wire can go throught to the fuse box and under the panles to the back. i ran a ground fron the T top mounts.. hope i was a little help
Old Jun 7, 2007 | 06:11 PM
dhighway's Avatar
I also have 91rs, i installed 3 amps under the rear hatch, with a sub box on top can strap it down to the t-top clips. also i recently changed my carpet from gray to black, and bundled all 3 sets of rca,s and ran them down the middle, the shorter the better. And then 4 gauge wire,from the batt, and fused there,along with a 12 gauge remote turn/on wire! down the pass side in shrink tubing. to a distribution box. also if you have a good set of 6x9,s and im sure you do, you should install dynamat along with dynaxorb behind them, sounds incredible. good luck, have fun, and no (short) cuts.
[IMG]local://upfiles/4539/BD56587B6C974B43A7E6798AF2996557.jpg[/IMG]
[IMG]local://upfiles/4539/DC10CD60C09D4F9CBB03B086BF2DD32E.jpg[/IMG]
[IMG]local://upfiles/4539/E2F7FA71E31141BF93D03E9C589C4364.jpg[/IMG]
NorthernCrew454
Aug 20, 2011 07:14 PM
9434V6
Aug 19, 2011 08:52 AM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
hshawn31
Jan 13, 2008 02:45 AM
twankieman91
Dec 19, 2007 06:46 AM
