thinking of getting a new head unit and subs
Old Dec 3, 2007 | 06:21 PM
driftingraver16's Avatar
Default thinking of getting a new head unit and subs
ok so heres the question im going to pick up a new head unit from best buy since i have a friend who works there, and have them install it but i want to get some subs and dont want to take up the space for the t tops can i modify the trunk where there is all that space not being used to mold it in between the "back seat" and where the t top are placed?? because if not ill just end up upgrading speakers
Old Dec 4, 2007 | 01:44 AM
CRanMaro99's Avatar
April 2008 ROTM
Default RE: thinking of getting a new head unit and subs
Anything is possible, depending on budget.
Old Dec 8, 2007 | 06:04 PM
Blu80_Blck89's Avatar
If you find that you cant modify like you would like to I recommend you replace your speakers with a set of Kicker components, or Polk components(both should come with tweeters) you will get pretty good bass and also you will get your highs.
Old Dec 9, 2007 | 01:03 PM
SilverBullet5's Avatar
Get the stealth enclosure and just get the best 10" sub you can find. That way you can leave the t-top part available and have your sub out of the way.
Old Dec 9, 2007 | 07:37 PM
sicked_wick's Avatar
exactly what silver said dude...they make custom camaro boxes or for any cars with a hatch so you can make the most out of your space. I think the highest they go in size is 12'. The only thing is they will run you a couple hundred but worth it if you would like to keep your t-top storage
Old Dec 10, 2007 | 10:14 AM
squisher's Avatar
Can be done, I used that empty space too, although several people have said that it's a major thief target.
https://camaroforums.com/m_120509/tm.htm
Old Dec 11, 2007 | 08:25 PM
Again like silver said you can get a nice set of ten inch subs. I work at Circuit City and right now they have a killer deal on Kicker Comp Subs 10" or 12" buy one get one free. 10" are 90 dollars each, 12" are 100 dollars each sale only goes for about another week though. Hope that's some help to you, if not it might be for whoever else reads this post.
Old Jan 21, 2008 | 09:33 PM
35thCamaro's Avatar
Check out the JL Audio Stealthboxes, they might be worth a shot too.
Old Jan 21, 2008 | 10:52 PM
98ss4Real said his roommate had an enclosure in his TAthat fit subs AND had storage for the t-tops...still waitin on a pic or link for that one also.
Old Jan 24, 2008 | 03:01 PM
squisher's Avatar
www.subthump.com -- look at the f-body section for the trunk box+T-Top storage
Got a stealth box too.
