Tail Light problems
Well one of my friends who was following me during the day said I had a tail light out, so I went and got a bulb. But right before I was going to put it in, I checked it myself, (when it was dark) and my right tail light was fine, but when you step on the brakes, the whole right side didn't work. So, I was wondering if it could be a fuse or something else electrical wrong with it?
2002 Camaro V6
2002 Camaro V6
had the same problem look in the socket where the bulb sits and clean it out and replace the bulb mine did that as soon as i got my camaro and cleaned it and replaced the bulb to be safe and its been fine since
the most efficient way to test those tail lights is to use a volt meter. if u have one set it to 12volts and test the voltage at the bulbs and at the fuse, if its not blown. also sometimes the fuses arent blown, but they just crack a little bit, so definitly check the voltage at the fuse.[:'(]
lonestarshinedown
Jun 8, 2015 12:39 AM
Mister
Aug 30, 2006 03:44 AM
