sub enclosure
Old Nov 25, 2008 | 03:53 PM
mikeman711's Avatar
Default sub enclosure
now i just bought 2 12" alpine type R, i dont have an amp yet, but i was thinking to get a rockford fosgate P1000-1bd but i am not sure, let me know what amp i should get, what i want to do is have the subs face tords the back window hatch, with a non ported box. but i am n ot sure what will sound better, for base, i listen to rock and rap music, and i was told that a un-ported box will work best for the rock music, please let me know what way i should face the box, and how whould i do it, i whould also like to still see out my back window, if possible, or i also found this website for my subs whould this be good. http://www.subthump.com/images/camaro/well/trip30th.jpg
Old Nov 25, 2008 | 05:18 PM
srs's Avatar
srs
Default RE: sub enclosure
Sealed boxes are great for rock. Tight and clean. Ported boxes are generally louder but not as crisp. For rock that means muddy bass drums. It's a pick your poison sort of thing. My preference is always sealed.
Old Nov 28, 2008 | 04:14 PM
RFxCamaro's Avatar
nice subs type rs are great you will be hitting hard if you get the p1000.1 but check the subs to see what ohms they are you should get the 4ohms to get the most out of the that amp. As for the box get a prefabricated box from any audio store because no matter what the hatch is going to make it sound great.
Old Dec 11, 2008 | 12:50 AM
Skippysnax's Avatar
alright noobs step aside. heres the plan patna, u get online, u go to audio enhancers website, u order a box for roughly 150, u get a legit thousand watt amp, not that sony bs, and then you wire the subs for 1000 watts. keep in mind i think that fosgate amp is 1000@1ohm, and u dont want to run the type r's at 1ohm,
check out my system, their 2 kicker comp vr's which is the exact same thing as a type r just a different brand.
Old Dec 22, 2008 | 03:57 AM
RFxCamaro's Avatar
o for the love of god please dont listen to Skippysnax, PLEASE. cvrs and type rs are not the same thing not by a long shot, type rs have some much better excursion. CVRs are pure **** and i would never run them again. Ive ran a 2xt1000 power fosgates one to each type r and they never ****ted it out. I ran ran a 501s to 2 CVR 10s and they could not handle it they struggled. Just because they ave similar ratings doesnt mean didly. As for the box walk into a audio express or best buy they should be able to get you a good box. U dont run subs at omhs u drive amps at one ohm and please dont listen to that bs about low ohms being dangerous your p1000 will run all day in summer at 1ohm, ive ran a dsm100 at .25 aka 1/4 of an ohm. That doesnt mean that you should run your p1000 at .25 ohms. Trust me your going to be banging with those type rs.
Old Dec 23, 2008 | 04:50 PM
mikeman711's Avatar
ok well thanks for the reply's now i just need to know if it is ok to run 600 watts to each sub my type r are 4 ohm because i was thinking i might go with 2 alpine pdx1.600 1 for each sub, i just want to make sure i am getting the full use out of my subs, or whould i be using the subs at full potential if i used alpine pdx 1.1000 and should i get a digital capacitor and if so should i get 1 for each sub. i am trying to make a all alpine system
Old Dec 24, 2008 | 10:07 PM
RFxCamaro's Avatar
mixing brands wont cause a problem, ive heard a p1000.1 with 2 type rs and it was bumping hard. the pdx1.600 run there max a 4ohm or 2ohm so they would work same for the 1000.1. The thing is that those are freakin expensive and not worth the price imho. I would get the p1000.1 or the power version t1000.1 realisticlly the p1000.1 is going to kick out about 1250 watts and the t1000.1 will kick out about 1400watts. So either way is good but i would go with fosgate because they are the better brand. As for a cap i wouldnt do it. Get a gel cell battery like kinetik or powermaster in the back and do the big 3
Old Dec 25, 2008 | 12:05 PM
mikeman711's Avatar
ok thanks but can some one explain how this works if a was going to get the
the p1000-1bd
rated at
Rated Power
continuous power
250W x 1 @ 4-Ohms RMS
500W x 1 @ 2-Ohms RMS
1000W x 1 @ 1-Ohm RMS
Total Power
total sum of 'rated power'
1000 Watts
or the t1000-1bd
rated at
Rated Power
continuous power
Total Power
1000 Watts
or the T1500-1bd
is rated at
Rated Power
continuous power
500W x 1 @ 4-Ohms RMS
1000W x 1 @ 2-Ohms RMS
1500W x 1 @ 1-Ohm RMS
Total Power
1500 Watts
and i wanted to run my alpines that are rated at 500 watt rms 4 ohms whouldint i need 1000 watts rms at 4ohms
please help
Old Dec 26, 2008 | 01:08 AM
RFxCamaro's Avatar
i would just get the p1000.1 or t1000.1 a t1000.1 on ebay goes for about $350and wire like the first pic and it will run at 1ohm
http://www.rockfordfosgate.com/rftec...p;woofer_imp=4
timmyz28
May 11, 2011 04:54 PM
Iceman1023d
Oct 22, 2008 04:30 PM
bill12690
Jan 3, 2007 11:48 PM
