Speedometer Light Size?
Old Sep 3, 2008 | 08:52 PM
TakeTtopsOff's Avatar
Default Speedometer Light Size?
Hey I've got a '98 and I'm looking to replace the lights in my speedometer, AC controls, and Lighting Controls. I'd like to replace them with blue LED's and I'm unsure of what size I would need and although I think I could do it pretty easily on my own, I'm not exactly sure how to do it. So if anyone knows what size bulbs and how many I would need and how to replace these lights b4 I rip everything apart I'd appreciate it. Thx
Old Sep 19, 2008 | 06:03 PM
th3po1son's Avatar
Default RE: Speedometer Light Size?
194
Old Sep 19, 2008 | 10:07 PM
02StanGT's Avatar
9 of the 194 bulbs for the gauges. The other interior will require some 74 size bulbs, not sure how many. You can figure that out easy enough though.
Old Sep 20, 2008 | 06:57 PM
RS96LSU's Avatar
they are 194 but i wouldnt recomend changing them. i thought it would look cool so i did it when i changed my gauges to white, but it looks terrible. they arent bright enough to see unless its pitch black outside and when u can see them, some are brighter than the others. it makes dark spots on my speedometer. i want to change them back to white but its such a pain to get to the gauge cluster. trust me man. it doesnt work
Old Sep 20, 2008 | 07:10 PM
02StanGT's Avatar
They look fine to me... These are mine by the way. Trust me, it does work. Have had no problems with them.
EDIT: Pic will not post right. Check out my FQuick pictures for some of the LEDs. Link in sig.
Old Sep 20, 2008 | 07:15 PM
RS96LSU's Avatar
i wonder why yours work when mine dont? what did u do to change them? i must have done something wrong
Old Sep 20, 2008 | 07:18 PM
RS96LSU's Avatar
why does your spedometer go to 150? i thought the 6s only went to 120
Old Sep 20, 2008 | 07:25 PM
02StanGT's Avatar
I put in a Z cluster.
Old Sep 20, 2008 | 07:51 PM
RS96LSU's Avatar
how did u do that? does it just plug in the same way as the v6 cluster does?
Old Sep 20, 2008 | 08:02 PM
02StanGT's Avatar
Yes, it plugs right in. Everything reads correct with the exception of the tach (reads 75% of what it should), and the oil pressure gauge. It points the same direction it would on the 6 cluster, it is just that the numbers are different on the Z cluster. I did have to put black tape over the SKIP SHIFT light and the ASR light, as I had heard that sometimes they light.
