size alternator?
Old Aug 21, 2007 | 09:14 PM
sweet1967camaro's Avatar
Default size alternator?
I have a 60 amp one wire alternator on my camaro now. Going from a flex fan to a dual 10 inch electric fan setup in the next couple of days and was wondering if I'm gonna need a bigger alternator. Supposedly each fan will only pull 8 amps a peice. I dont have any electronics on the car, except radio and the usual, headlights etc? Can anyone help me out here, what size alternator should be sufficient? thanks
Old Aug 22, 2007 | 06:43 AM
94Red's Avatar
Default RE: size alternator?
I think the 105 Amp would be mor then enough, thats what i have on my 1994 3.4, i got my fans, radio (1500 watt) system, and lights and all that **** and never noticed a problem.
Old Aug 22, 2007 | 07:21 AM
blackz87's Avatar
105 amp will be enough.
Old Aug 22, 2007 | 12:43 PM
would i have to worry about it overcharging my battery than?
Old Aug 22, 2007 | 04:07 PM
blackz87's Avatar
ORIGINAL: sweet1967camaro
No, you will not have any electrical or charging problems. A 105 ampalternator is stockon v8 Camaros.
Old Aug 23, 2007 | 01:28 AM
94Red's Avatar
Youll have no problem with it bro, 1-wire set-up IS THE ****! lol
Old Aug 23, 2007 | 10:00 AM
As long as the voltage regulator part works properly you can have a 1,000 AMP industrial alternator running in your car and it won't overcharge your battery; however, an undersized alternator may not be able to produce enough power to keep the battery charged. But, don't overdo the size of the alternator as you may have to put dualies at the front of the car to carry the weight. LOL. That 60 AMP unit you are using is not going to do too well when you turn everything on.
deez28
Oct 21, 2013 08:56 AM
WIspartan1026
Jun 7, 2011 04:36 PM
Dana
May 18, 2011 07:42 PM
microkid
Dec 20, 2010 08:59 PM
