New Deck
Old Oct 27, 2007 | 07:21 PM
EddieTheRipper's Avatar
Default New Deck
Im installing a new head unit in my 86 z28 IrocZ, ive got all the wires soddered together that i need except for a solid blue wire for the power antenna. the antenna on the car is broken off (vandalized). and my question is do i have to hook up the wire to make the antenna pickup the radio signal?or is the wire just to make the motor move it up and down? cause if the wire is just for the motor ill use that for a amp signal instead, and buy a solid antenna so i can still have the radio... screw the power antenna ..junk thanks for the help in advance.
Old Oct 29, 2007 | 07:44 AM
squisher's Avatar
Default RE: New Deck
That wire is just for making it go up and down. You can use it for an amplifier remote if you want. If your new deck has one though, I would use the one labled "remote" (I usually see either one or the other though)
Your actual signal from the antenna is usually a black encased wire that is fairly large around (1/4" or so diameter) that plugs in separately from the main harness.
moparmusclecars
Apr 22, 2014 11:34 AM
mikes68
Nov 27, 2011 06:21 PM
LT1ChevyBoy
Feb 6, 2011 09:55 AM
McGnrAcDcfan227
Oct 28, 2009 01:20 PM
Z28midwest_08
Dec 21, 2007 11:45 PM
