LED hyperflash sometimes?
Old Aug 17, 2023 | 07:32 PM
legowheels748@gmail.com's Avatar
Default LED hyperflash sometimes?
Hello all, I recently got tasked with installing the morimoto headlights and taillights on a 2017 SS and have been having some hyperflashing issues. The lights will blink normally for about two or three blinks then hyper flash. If I shut it off and turn the turn signal back on same thing, blink normally a couple times before hyperflashing until it turns off. Both the headlights and taillights come with pre-installed resistors that are plugged in, unplugging them has no change either. Hazards work normally however, as well as the brake lights and reverse lights. I've seen the LED harness for the non-rs models but there it says it only works for the factory housings. These lights were all plug and play but I don't know if it'll work. Any one have had a similar issue? I have attached a video to show what I'm talking about.
Jward6222
Apr 23, 2018 04:59 PM
Danlp1
Feb 25, 2017 02:50 PM
mfmfim
Mar 31, 2013 01:07 AM
UFGatorFan
Jun 21, 2012 11:50 PM
97rsturbocamaro
Nov 2, 2007 06:31 AM
