Headunit removal
Ok I have a 96 Camaro w/ Bosethat I had Best Buy install a Pioneer DEH P4900ib headunit into. Now I'm trying to sell the Camaro and I want to take out the Pioneer and just put back in the Bose headunit. Will I need to remove the dash to do this? What strange tools if any will I need to do the job? And will I have to change out the antenna or how does that all work?
Alright the funny thing is ive got a 96 camaro w/bose and a pioneer. so ur in luck. Alright man first of all u will need a 7mm wrench(ratcheting if possible) then u will need to pull some of the dash panels off. i think its like one or two. then u will need a set of pioneer keys to pull the pioneer out of the cage. Go to circuit city, i work there, and theyll hook a brother up. Then ull need to pull all the aftermarket harnesses off. as well as an antenna adaptor. from there u will need to pull the dash kit out(that black plastic crap) and replace the oem brackets, and hook everything up in the correct areas.
However u probably dont even need to know this, because i know at Circuit City we unistall decks that we have put in, for free. Best Buy should have the same policy, if not tell them their gay.
End of story
End of story
