finding electric problem?
RE: finding electric problem?
First whats the problem, We may be able to help out without the whole electrician thing,is it a problem with the house? or are you in need of a mechanic? Whats going wrong,and where?
lol sorry , well its my 94z, when i open the door the lights from the rearview mirror should turn on, but it dosent. i check the bulbs and they are good, also the same with the with the trunk it dosent seem to open with the button inside the glove box. also the light in the back, its ontop of the passangers seat, that light does not turn on either.
Check the fuse box and if all is good there look and see if there is anything unhooked. If there is an after marcket radio in the car odd's are some wires may have been un done. I'm not sure but I think that stuff is in all one harnes and fuse.
thankx guys yeah it was fuse #8 you were right z28pete, and well i thought i had check that fuse and tested good, but then again i guess not, well my trunk works now, my radio works now, and all the other stuff mention.thanx guys
