A challenge for you audio wizards.
Old May 15, 2008 | 10:34 PM
Fycko's Avatar
Default A challenge for you audio wizards.
I have a '95 camaro with a stock Bose deck.
I just got a new Zune player.
Here's the question: how do you merge the two?
Any help is appriciated.
Old May 15, 2008 | 11:09 PM
bill12690's Avatar
Default RE: A challenge for you audio wizards.
one way you could do it, and probably the easiest is to get an FM transmitter, and plug that into your zune. Some FM transmitters get interference though, i assume they all can, but some do it more than others.
Old May 16, 2008 | 12:39 AM
itcantbestephen's Avatar
If you have a tape deck, get a tape adapter. That's what I used in my old '89 Silvy with the stock radio. I think that's the best way to connect an MP3 player, next to a true AUX input.
Old May 16, 2008 | 02:31 PM
ph0enix's Avatar
Go for what stephen said and go with the AUX if you can, it'll have the best quality.
It'll be the hardest approach, but well worth it, if you can do the install.
http://www.crutchfield.com/App/Produ...dmenu3*spg_770
Crutchfield sells a lot of amazing stuff.
Old May 16, 2008 | 05:31 PM
bill12690's Avatar
yeah, that is definately a better way..
Old May 21, 2008 | 11:00 PM
akbyrner92's Avatar
Eh, if I were you I'd do what I did to mine, get a new deck and just make sure that you get one with an AUX input and use that. I plugged my zune into one of those new fords with the sync system and it only sounded a tad bit better than AUX, and AUX is going to be cheaper than those car adapters and it's 10x easier to install.
SDlivin
Mar 6, 2023 07:56 PM
jonclem
Sep 8, 2005 01:23 AM
