cd players
Old Jun 9, 2006 | 02:48 AM
2fast4u's Avatar
Default cd players
hey i was wondering what it takes to hook up a simple aftermarket cd player to a second gen, is it possible, wat it would take, so on and ,secondly a queston on rader dectectors are they worth the money plain and simple let me know
Old Jun 9, 2006 | 07:04 PM
02renegade's Avatar
Default RE: cd players
Not a problem to do at all, if your dash is set up for the old 2 **** style of radio all you have to do is cut your dash out to accept the new "Din" (square) style of radio. As far as wiring goes their is a aftermarket plug that goes back to '78 that will plug right into the car, if this will not work for you all you need to do is run a couple wires to the fuse box 1 for constant power and 1 the turns on and off with key switch, then a ground wire and hook up your speakers, plug in the antenna and away you go!
