ABS,ARS,CEL,SECURITY, BRAKE lights stay on
Old Jul 18, 2010 | 03:25 AM
Adam_muz's Avatar
Default ABS,ARS,CEL,SECURITY, BRAKE lights stay on
Hello everyone i just bought a 2000 CAMARO SS and all the items i mentioned in the title are on and idk what the problem is i checked fuses and idk how to make these lights go away.. some input would be apperciated..
Old Jul 18, 2010 | 07:09 AM
first check all your tail light bulbs to see if any are burnt out. if so replace and see if that helps, then have it scanned for codes.
Old Jul 18, 2010 | 09:02 PM
Adam_muz's Avatar
wel i ended up changing all the fuses.. under the hood and the interior ones, and then all the lights went away =) thanks for your input
Old Jul 18, 2010 | 09:49 PM
that reset the computer. they may or may not come back, lol,. go to hear you got it.
Old Jul 18, 2010 | 10:12 PM
Double check the BRAKE lite. It could be on because the parking brake is hanging on, or it could be a serious brake problem, such as low fluid, bad master cylinder, or even a leaky hose.
Old Jul 18, 2010 | 11:25 PM
Adam_muz's Avatar
alright ill double check the brake light because when i pull the parking brake up the light doesnt even come on.. so thats what im doing tomorrow
grant morgan
70-81 V8 Tech
Sep 14, 2011 12:21 AM
jeffs1985z28
May 13, 2008 06:41 AM
rdman
Mar 11, 2008 09:08 PM
3.4CamaroCDOG
Mar 2, 2008 11:55 AM
apollo
Oct 24, 2007 01:54 PM
