92 camaro audio system blows 150 amp fuse?
whats up guys? i have a 92 rs 25th it has pioneer p6000ub hu,4 rockfordfosgate 4x6s,4 memphis 6x9s,2 fosgate 6.5s kicker kx650.4 .also has2 fosgate p2 10s ported with crunch 700.2,blue top optima and double zero awg back to a 4 way distro block .....now i have a 150 amp fuse in the doublezero , and after about 5 min of gettin down it will blow, i dont see a reason for this any ideas? i was about to upgrade my mids amp to kicker sx 900.4 and bulid me a custom box in rear for 3 mtx ts 85 10s but if im blowin 150 amp now should i just go bigger fuse?
yes it was in power wire it started yesterday , it would play fine then if bass was on for a min it pop,, any ways i traced power wire and found the the wire came out a little bit and would shake and touch body so i fixed that and i'm good to go .. so now im going to go to lowes and get some 1/2 inch mdf and start my new box
, im going with 3 mtx ts 55 10s in 1.75 cubes each ported off the back glass , anyone used these subs?
