4th gen HID install (sealed beams too)
Old Dec 3, 2008 | 03:27 PM
02StanGT's Avatar
Default RE: 4th gen HID install (sealed beams too)
Yes. I put the brackets on the ballasts, then bolted the brackets to the pieces where the hood rests. Brackets are pretty stiff, so they aren't just swinging around.
Old Dec 3, 2008 | 03:30 PM
tipdrip215's Avatar
well, my car is all stock under the hood, so ill have to find a different way to run the driver's side wire since i dont have that vacant air duct spot like you do.
Old Dec 15, 2008 | 04:00 PM
tipdrip215's Avatar
yeah they are sealed beams, but eurolights.com sells H4701 and H4703 kits for 98-02 birds as well. however, if you have a 97 or older (H4666) they dont have anything for that yet.
Old Dec 15, 2008 | 04:10 PM
tipdrip215's Avatar
just installed my HIDs. ordered a lowbeam conversion kit from eurolights.com on the 4th, and got them saturday, and went right to work installing them. turns out, there were no ballasts needed, and no wiring at all. it ended up being just like changinga halogen bulb. now the car looks so awesome. only problems i ran into were the usual camaro headlight changing problems (getting the tabs on the side of the frame into the slots, etc.) the bulbs on the new housings are held in place by gold tabs, i ended up having to bend those slightly with tweezers to give myself more room to wigglethe housingaround and not havethe pinstouch the side of the mounting area when i was pushing the back through the hole after plugging the wire in. also had to mess with the aiming screws a little bit to help with fitting the frame back on on both sides, but other than that, the installation is cake, and the lights are so awesome.
Old Dec 18, 2008 | 04:35 PM
02StanGT's Avatar
Not trying to knock on your lights, but so everyone doesn't get confused: True HID kits come with a ballast for each bulb. If the bulb has a filament in it, it is not HID. True HID is just a bulb with gas inside. As the gas heats up, it becomes less resistant, and gets brighter and brighter til it no workie anymore. The ballast regulates the current and voltage, so the light doesn't kill itself. The gas in "Xenon charged" bulbs is supposed to help them last longer from what I understand.
Old Dec 19, 2008 | 03:50 PM
tipdrip215's Avatar
ohh ok. well still the eurolights are pretty darned good if you want HID looks without being able to tell that they aren't actually HID.
Old Jan 15, 2009 | 06:57 PM
leeai's Avatar
Default Who needs that much velcro?
Why would anyone need that much velcro? These guys sell it by the roll http://www.liangdianup.com/miscellaneous_1.htm and is
hook and look and velcro the same thing?
Old Jan 15, 2009 | 07:21 PM
02StanGT's Avatar
What the hell are you talking about?
Old Jan 16, 2009 | 08:20 PM
torque_is_good's Avatar
I believe; velcro. I ordered up a roll for when i do my lights too :-)
Old Jan 16, 2009 | 11:15 PM
  #20
02StanGT's Avatar
When the hell was velcro even mentioned? I mean before Peabody came in here talking about a website he knows that sells velcro.
