whats the deal with the rust
Old Mar 11, 2013 | 06:14 AM
cherijonmaui's Avatar
Default whats the deal with the rust
just had my brakes done a month ago
What is this rust from??i have owned this car for many years never have I seen rust what is this??help?
Old Mar 11, 2013 | 06:16 AM
Old Mar 11, 2013 | 08:18 AM
could be brake pad dust, what color are your brake pads.
Old Mar 11, 2013 | 08:26 AM
im not sure but they are supposed to be brand new!I will check though thanks for the tip
ps they also make noise every so often i have never had NY rust problems like this
Old Mar 11, 2013 | 08:34 AM
were the rotors changed when brake job was done? also after driving the car for a fair length trip check the rotors for heat, excess heat will cause rust to form fast or can cause a color change in the steel.
Old Mar 11, 2013 | 11:24 AM
Brake rotors are bare metal, they do rust unless you paint the non-pad surface.
Even the pad surface of the rotor will rust if the car sits long enough, but the brake pads will clean them back off.
What you have there is normal.
Old Mar 11, 2013 | 10:50 PM
Yes the rotors were replaced as well as pads.They were replaced two months and suddenly look like something out of a junk yard.
I am puzzled though why this is the first time I have ever noticed any sign of rust let alone the huge amount that has accumulated in two months time.I n the twelve years I have had the car I have never come across this.Although I am relieved to hear it is normal but am left wondering why now suddenly could it be poor quality or maybe replaced with a something different ?I appreciate all the replies and help from everyone i love learning about my car
Old Mar 12, 2013 | 01:23 AM
Don't know whether your old rotors had a rust preventive coating on them or not, but there's nothing on bare untreated metal (or cast iron) to prevent rust.
With wheels that show the rotors, I always give the hat of the rotor a shot of Rustoleum paint.
Old Mar 12, 2013 | 02:39 AM
Thanks that helps to know.Appreciate your reply as always
Old Mar 12, 2013 | 08:19 AM
metal based pads can cause a rust looking dust to cover rotor and wheel as well. thats such an odd color that the first thing i thought of was pad dust.
