Spacers or BFH?
So I got some Vette wheels for my Camaro and the are rubbing the inner fender. They are size 295 and Im thinking about just getting some spacers about a 1/4" thick. But if i do this i don't know if i will have to do something else to the lug nuts, so they will be able to get more threads. Does anyone know if using 1/4" spacers would work without any other modifications? And would if it would screw with the alignment or performance? Or any suggestions on a different solution.
Its for a 2002 Camaro SS.
I'd rather go spacers that beat the crap out of my fender well, but that's just me.
If you go with longer wheel studs, it should be fine. I am pretty sure you can get either hub-centric or stud-centric spacers to ensure they align correctly.
Edit: Here is a set for $150 at a local jobber: "Wheel Spacers"
I'm sure they carry the longer studs too... (Edit) Comes with longer studs!
