Running older tires...
Old Jul 17, 2021 | 02:59 PM
Mark'95Z's Avatar
Default Running older tires...
I have a '95 Z28, 11,000 miles with the original Goodyear 235/55R16 Eagle GA tires. No sidewall dry cracks, some cracking between the treads but not deep. I knew tires back in high school working for Goodrich (1972), but I don't recall much on how long you should run older tires. Seems to me 7+ years is about enough. I read recently about a guy running 20 year old tires without issue, but I'm not so sure that's a good idea, especially at highway speeds obviously.
Any thoughts are welcome, going to be expensive putting new rubber on this beast, but I'd likely upgrade to the Goodrich G-Force 245/50R16s. Can't find white lettered tires anywhere in these sizes. Thanks in advance!
Old Jul 17, 2021 | 09:27 PM
I wouldn't run anything older than about 5 years on a performance car that I might go high speeds in and 20 years? well hell no on anything!
Old Jul 19, 2021 | 09:38 PM
In PA any dry rot will fail state safety inspection. It may be fine in a normal situations but in a emergency situation at 70 MPH it may not be ok.
I have seen a lot of Youtube videos of rescued cars running on old tires and everything was fine. But I have seen a few that ended badly.
Keep in mind just because one or two people do something it does not mean it is statically significant. Yea I could drive on old tires and never have an issue or the first time I take it on the highway a semi rim could fly out of the back of a scrap truck and I slam on the brakes the front tread rips off the passengers side and bam I am in the divider. ( Oddly specific dont you think )
Old Jul 30, 2021 | 02:53 PM
Mark'95Z's Avatar
New tires it is, thanks for the input. FYI, from additional reading I've done 6 years is about "normal", 10 years it's time to replace if not sooner.
Old Jul 31, 2021 | 05:21 PM
LastRS's Avatar
I replace my tires if they are older than 10 years, as the rubber gets hard, and they are suseptable to tread separation. This is even worse than a blow out.
If I were in your shoes, given the age of the car and the low mileage, I'd buy new wheels and tires and store the originals.
Old Jul 31, 2021 | 10:03 PM
Mark'95Z's Avatar
Thanks, not a bad idea, except I’m planning to put the car up for sale soon, so no need to invest in new wheels. Finding tires in the sizes noted earlier has been a challenge, and no raised white letters anywhere that I’ve found. Strange. Probably I’ll just leave the originals on board and let the new owner make those calls.
Old Aug 1, 2021 | 09:00 AM
Factory tire size should be P245/50ZR16.
guardian452
Jul 30, 2017 09:38 PM
Fterr99ss
LS Series Tech
May 1, 2011 08:10 PM
DarlingReject
Sep 12, 2009 10:44 AM
th3po1son
Nov 11, 2007 08:16 AM
Lil_427
Jul 6, 2006 08:26 PM
