Rims and Wheels for the Camaro of the 4th gen
Old Mar 21, 2014 | 12:20 PM
chrisbuss's Avatar
Default Rims and Wheels for the Camaro of the 4th gen
Hallo people,
I habe bought an camaro V6 3.8 from 2000. I need nice rims and wheels for the car. What are the best for it? Did BMW circle 120 rims pass at the camaro?
Greets from Germany
Sry for the broken english
Old Mar 21, 2014 | 02:39 PM
camaroteen82's Avatar
the BMW's bolt pattern of 120mm and the camaro's bolt of 5x4.75/120.65 aren't the same. you may be able to get some bmw wheels to bolt onto your camaro but if you're in a wreck having the wrong bolt pattern rims can put you at fault even if it wasn't your fault. Summitracing.com and Jegs.com have a lot of decent rims for camaros or you can try ebay. I personally run 17x10 in the back and soon to have 17x9 in the front. you can go bigger but theres really no point in it unless you don't plan on going faster then the speed limit.
Old Mar 22, 2014 | 08:00 AM
chrisbuss's Avatar
Hello,
Thank you for lot of informations! That was very helpful for me. In germany, there are many laws and descriptions to drive with the wheel-rim combinations at the cars.
Old Mar 22, 2014 | 09:30 AM
Jim in Indy's Avatar
I'm running Corvette ZR-1 look-a-likes, 18X8.5" front and 18X9.5" rear on my 1996 3.8 convertible, with a 49mm offset, and are on a 4 3/4" bolt circle. Tires are Dunlop 101's, 245/40x18 front, and 275/35x18 rear. They fit just fine.
(I used to live & work in Zweibrucken, so I know how the TUV inspections can be.)
dblit95
Aug 6, 2012 11:22 AM
luciora
Apr 12, 2010 08:18 PM
inter4life47
Nov 17, 2008 01:29 AM
TakeTtopsOff
Oct 20, 2007 09:24 AM
fasted
Jul 23, 2007 11:01 AM
