New Tires
Old Sep 7, 2012 | 10:18 AM
jkeaton's Avatar
Default New Tires
Picked up some Hankook Ventus V12 's on sale from Discount Tire, righht at @$110 each. Got 255/40-17 (25.03" dia) for the back, 245/45-17 (25.68" dia) for the front. I hope it is an optical illusion because the sidewall is an inch less than the 245/50-16's (25.64" dia)I had on before. Almost looks like the tires are too small. What you think? Or is the body kit adding to the illusion?
Just seems like the 245/50-16'S filled out the wheel wells a little more. Probably because I got less tire and more rim now with the 17's.
Old Sep 7, 2012 | 03:52 PM
blackz87's Avatar
My opinion is that you should went with 45 sidewall front and back. That 40 aspect ratio looks small with that sidewall. I have a 3rd gen with 245/45/17's ft & rear.
Attached Thumbnails New Tires-blackz-beach.jpg   New Tires-17-x-8.5-wheels-245-45-17-tires.jpg
Old Sep 7, 2012 | 04:16 PM
Edwardgp's Avatar
Ah man they probably wont let you take them back and trade.
Old Sep 7, 2012 | 10:12 PM
jkeaton's Avatar
I'm going to take it back and try
Old Sep 7, 2012 | 10:44 PM
AboveTheLogic's Avatar
Yeah those 40 series are shorter lookin'. I'd have gone with the same 245/45/17 all around, that way you can rotate them. The difference in width is minimal.
Old Sep 8, 2012 | 01:24 PM
jkeaton's Avatar
Yeah. I agree. I did all the research. Figured oh its only .6" difference...makes a heck of a difference in real life. May cost me some but I'm exchanging them.
Old Sep 8, 2012 | 05:50 PM
Edwardgp's Avatar
Oh my that's to bad they are not going along with the game plan.
Old Sep 8, 2012 | 08:33 PM
jkeaton's Avatar
Don't know that. Have not talked to them yet...
Old Sep 8, 2012 | 08:37 PM
BasicConcepts's Avatar
Technical User
not 100% but iirc discount has a grace period in which if you dont like the tires theyll let you swap them out. probably gotta pay the install fees again tho.
Old Sep 9, 2012 | 01:25 AM
I remember something about that, discount is much better than most other places about returns. You might be fine.
I remember reading about the +1 width and -1 aspect ratio = same height rule, it is definitely not right, and a lot of lesser-experienced tire sales guys will just follow that rule and you can see how that worked out...
IME it is usually +2 or 3 width and -1 aspect ratio, so if you want the same height, you'd pair a 245/45/17 with a 275/40/17 or even a 265/40/17 if they even make that size
I paired up 205/55/16s with 225/50/16s on my old 240Z and that worked fine. Worked well to replace the original 195/70/14s.
Also a popular width upgrade for the 235/75/15 was the 255/70/15 or even the 265/70/15 which is a bit more rare. 10 years ago, you could find a LOT of tires in 255/70/15 although no vehicle came stock in that size (at the time). That's because it was so popular for trucks and SUVs as a width upgrade. NOT the 245/70/15....
Another interesting example is the 70's vettes. They came stock with either a 225/70/15 or a 255/60/15. I have to believe that switching from the 225/70 to the 255/60 caused some speedometer error.
I could go on and on...
