-   93-02 Wheels, Tires and Exterior (https://camaroforums.com/forum/93-02-wheels-tires-exterior-127/)
-   -   93-96 tail lights (https://camaroforums.com/forum/93-02-wheels-tires-exterior-127/93-96-tail-lights-73837/)
Fross Apr 3, 2013 11:51 AM
93-96 tail lights
I'm from France, so please excuse me for my poor english. :icon_shrug:
I've some questions about 4th-gen Camaro tail lights.
I prefer the 93-96 tail lights than the 97-02 ones (although the first ones are not legal here cause the blinker must be amber and not red).
Is it possible to install the 93-96 tail lights on a 99 Camaro?
Is it a direct replacement or does it need a re-wiring job?
Thank you,
Francois
Camaro 69 Apr 3, 2013 12:07 PM
I had a 96 and updated it to the 97-up tail lights. I used the same sockets, but the notches in the light housings needed to be trimmed to accommodate the existing sockets (they are patterned slightly differently). So given that, I see no reason why the opposite wouldn't hold true.
Fross Apr 3, 2013 12:33 PM
Thanks 69,
Does it need a heavy trimming on the notches?
Camaro 69 Apr 3, 2013 12:34 PM
No, just some elongating. And not all of them needed a trim. You'll see when you go to line it up.
Fross Apr 3, 2013 12:40 PM
OK.
Now, just have to find a decent pair for cheap... :D
Thanks,
Francois
Fross Apr 3, 2013 12:48 PM
Oh... a last question.
I've never seen a 93-96 tail light in action.
What's the illumination pattern?
The blinker light is on the outer tip, and the brake light in the center? or inversely?
Camaro 69 Apr 3, 2013 01:04 PM
Gonna need someone else to answer that, I don't have one to look at any more! ;)
Fross Apr 3, 2013 01:46 PM
Bah... anyway, if I do the swap, I will modify the wiring to get a total illumination for the tail light, the brake light and the blinker. ;)
9434V6 Apr 3, 2013 06:28 PM
the light pattern if you look at the right side lens is reverse, driving, driving/turn/brake, driving. only the center bulb does anything different. you can rewire them to all work, but they wont work properly. if you want the whole lens to work, you need to do what I did. You need 4 more of those center bulbs with the 2 filaments and the accessory wire. If it doesnt have the 3rd wire, it wont work. You replace the inside bulb with that one. The outside bulb is smaller though, so you will need to dremel out the hole a bit to fit the new bulb in. dont just put in a bigger hole though. make it big enough to put the new bulb in, then take a smaller tip and put notches in so the bulb still secures normally.
Camaro 69 Apr 3, 2013 06:36 PM
Man, that's more of a pain. To go from old style to 97-up, I didn't have to change a thing.
All the lights (running, turn, brake, reverse) worked just fine.
