19X10 up front
Old May 31, 2012 | 08:21 AM
Slick6's Avatar
Default 19X10 up front
I want the same C6 wheels i got but 19 on all four corners, I have 18x9.5 X 4 ... I know its only 1/2" but can i fit the 19x10s up front with a 56mm offset and 275 tire?
thx -cale
Old Jun 4, 2012 | 11:55 AM
RumbleZ's Avatar
yes. I have 19x10 C6's with 295's on the front of mine with a 56mm offset. I am going to be adding a 1/4 inch spacer though as the tires are very close to the upper ball joint nut. I knew they would stick in a bit though and added the longer ARP lug studs beforehand so I could add the spacer.
streetsteve
13
Jun 5, 2012 06:44 AM
doinbout150
Oct 8, 2007 09:32 PM
CasperOn20s
Mar 21, 2007 06:52 PM
